TheCHIMP_net
Dec 25, 2008Aspirant
Default Admin/Netgear1 Logon Doesnt Work (#8463338)
Hello Forum Long time reader, finally got the ReadyNas Duo 2150 for Chirstmas today! Very excited and was already planning my "wow, this set up incredibly easy" post of recommendation when I got to...
MHECS
Sep 13, 2011Aspirant
The true solution: In your browser enter the ip address for your ReadyNAS Duo (2000 Model). For example: http://192.168.1.IP where IP = ReadyNAS ip address. Can also be found using the Raidar software by clicking setup button.
The enter this ending after the IP for example: http//192.168.1.55/password_recovery this allows you access through your home network to change the netgear1 password stated in the manual to anything you choose. Once you do this you should see the ReadyNAS UI for password recovery. Only peole on your home network can view this screen.
Change the password and then close the window then go to your Raidar Software and click the setup button. You will be asked for he login which is username = admin and password = new password and not netgear1.
This solution cannot be found online or in the manual this is why I am posting this solution.
