BaJohn
Feb 16, 2015Virtuoso
Defrag - Find out how long?
Being new to ReadyNAS there were various things I wanted to know. One of these was about the Defrag process and how long it takes to run. Having trawled through the forums, one thing is apparent. ...
Mar 05, 2015Guru - Experienced User
I've seen some posts in other places that suggest ~80 MB/s for ~5900 rpm drives is a reasonable estimate for scrubbing. Though it seems to be quite variable.
However, if it's correct then a scrub with 2x2TB Red drives should take about 7 hours, not 200.
Perhaps try running the experiment again, but let it keep going for 10-12 hours before canceling?
