Antsa
Jun 08, 2025Aspirant
Degraded volume after resync
I have a reasonably old RN314 which I have had to fix up some failing drives. Having resynced the volume from one disk to a new hot spare, the volume says it's still degraded. I have tried to pos...
Jun 10, 2025Guru - Experienced User
I agree with @Sandshark that you should first back up the data.
The disks are of course old, with sdb showing 10 years of power-on hours (88478). Did you also look at smart_history.log?
I would treat a self-test failure seriously. You could power down the NAS, connect the disks to a PC and check them with WD tools (their current tools is KitFox).
Make sure the NAS remains powered down until you reinsert the disks.
- AntsaJun 10, 2025Aspirant
Thanks for the replies - yes, backups have been done when I first noticed the disks failing. I've been reluctant to power down in case it never came back. The NAS is pretty much read-only these days, and I keep wondering if I really need to replace it. Probably due to procrasination, I think I'm going to wake up one morning and wonder why my music is no longer playing :)
