jjmanning
Feb 04, 2014Aspirant
Desperately need data on a unit with dead NIC
I have ready many posts that the ReadyNAS Duo v2 has NIC issues. My NIC is dead and i have tried all the troubleshooting from other posts. I desperately need access to my Data though. My warranty is ...
vandermerwe
Feb 04, 2014Master
Are you sure you have a duo v2?
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Easiest would be to backup to a usb disk, make sure you format the disk in fat or ntfs so you can read it using a PC.
You could also read one of the disks using Linux reader on a PC. If you do this only remove and reinsert the disk with the Nas off.
http://www.diskinternals.com/linux-reader
You can put the disks in another duo v2 or nv+v2 EDIT (if you have a v2) or a Duo v1 or NV+ v1 (if you have a Duo v1) Make sure:
1 You remove them with the unit off and insert with the other unit off.
2 You insert them in the same order
3 You have the same or later firmware on the new Nas.
