NoGravityCarlos
Dec 23, 2021Aspirant
Destroyed Raid at disk replacement
Dear Helpers :) Morning did not start good for me. Sleepy, and less of conscious I have started replacing disk. I have took off first drive from raid, put new one, and instead of destroy and fo...
NoGravityCarlos
raid mode was flex-raid,
3x3TB+1x4TB - new one
i have started last drive replacing from 3TB>4TB few days ago and finished today morning, then started replacing first first drive,
no config backups or data,
so theorethicaly I have got old 1st disk out of NAS still keeping old configuration and part data,
1st new disk still in raid (not touched yet)
3xold raid drives in raid with data with destroyed volume/raid
what confused me to click the wrong set?
first time - main raid was at first place and spare on bottom
second time - spare drive was displayed as first and rest of raid in the bottom
regards,
Carlos
Dec 23, 2021Guru - Experienced User
I don't know of any way to undo the mistake.
One option is to contact paid Netgear support, and get a data recovery contract. https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
You could also try RAID recovery software (getting a package that supports BTRFS). ReclaiMe is one that several folks here have used with success. You'd need a way to connect the disks to a PC - either SATA or through USB adapter/docks (possibly a USB enclosure).
- NoGravityCarlosDec 23, 2021Aspirant
Well, I still have disk 1 and 4 before i have started upgrading them, would it help?
- StephenBDec 23, 2021Guru - Experienced User
Maybe. But my guess is that recovery of data from the disks in the array when you destroyed the volume would be the best path forward. Not sure if Netgear can "undestroy" that volume or not - but I'd start with them, since there is a chance that they can.
The older disks will probably will be out of sync - sorting out the best path to recovery will take some analysis, and perhaps some trial and error.
Where to extract these files? it contains previous configuration
and what else I should find?
-rw-r--r-- 1 root root 16464 Dec 20 21:36 raid_config_data-0_2021_12_20_213637.tar.xz
-rw-r--r-- 1 root root 16388 Dec 23 07:15 raid_config_data-0_2021_12_23_071534.tar.xz
-rw-r--r-- 1 root root 16388 Dec 23 07:15 raid_config_data-0_2021_12_23_071535.tar.xz
