Airat
Dec 20, 2015Aspirant
Device is offline please wait
Checked other topics with same topic but did not find answer. I have SSH enabled and tried this root@ttk-nas-77:/etc/init.d# systemctl status readynasd readynasd.service - ReadyNAS System Daemo...
JennC
Dec 22, 2015NETGEAR Employee Retired
Hello Airat,
Welcome to the community!
I have some questions to ask, they are listed below:
- Do you still have access to the shares?
- What is the firmware version?
- What exactly is the message when you attempt to open the admin page?
- Have you tried other web browsers?
Airat
Dec 22, 2015Aspirant
Ok. The last problem solved by rebooting the device, but i've got new issue after that. I updated the software to 6.4.0 and device became very slow.
Connected via ssh and top command displays this that kworker process uses 100% cpu
top - 09:55:52 up 19 min, 1 user, load average: 3.02, 2.77, 2.21
Tasks: 186 total, 2 running, 184 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.3 us, 50.2 sy, 0.0 ni, 49.5 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 2065828 total, 1223880 used, 841948 free, 10252 buffers
KiB Swap: 1046524 total, 0 used, 1046524 free, 1067628 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1122 root 20 0 0 0 0 R 99.0 0.0 18:18.13 kworker/u4:5
6123 root 20 0 5544 2640 2216 R 0.7 0.1 0:00.06 top
9 root rt 0 0 0 0 S 0.3 0.0 0:04.80 migration/0
10 root rt 0 0 0 0 S 0.3 0.0 0:05.38 migration/1
3390 mysql 20 0 319m 37m 9520 S 0.3 1.8 0:02.30 mysqld
1 root 20 0 7360 5108 3072 S 0.0 0.2 0:05.35 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:01.79 ksoftirqd/0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
7 root 20 0 0 0 0 S 0.0 0.0 0:02.40 rcu_sched
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
11 root 20 0 0 0 0 S 0.0 0.0 0:00.49 ksoftirqd/1
13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0H
- mdgm-ntgrDec 22, 2015NETGEAR Employee Retired
After updating to 6.4.0 it could take some time for some updates to take place. If it remains slow then you could possibly try 6.4.2 Beta 1.
- AiratDec 23, 2015Aspirant
How do I get it?
Is there any way to go back to 6.2.5?
- StephenBDec 23, 2015Guru - Experienced User
Airat wrote:
How do I get it?
In the beta release subforum here. https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-4-2-T59-Beta-1/m-p/1021469#U1021469
Yes, but the process requires a factory reset - so you need to have a full backup in order to downgrade below 6.4.0.
