Ursusprimus
Mar 08, 2021Follower
Device shown as offline
I haven't used my NAS for a while which I'd like to change now. However, I can't access it. It's shown as offline in ReadyCloud, although ''ve connected it ro my router via LAN. In the router it's ...
- Mar 11, 2021
Hi Ursusprimus,
Welcome to the Community!
You can try first logging into the local admin page of the NAS by accessing https://<ReadyNAS IP address>/admin on your web browser. After logging in, you can go to the Cloud tab, then check the Internet and Service status. Both of them should have a green check.
You can also check if the ReadyCLOUD service is enabled when you go to the Cloud tab.
Regards,.
JohnCM_S
Mar 11, 2021NETGEAR Employee Retired
Hi Ursusprimus,
Regards,.
Mar 11, 2021Guru - Experienced User
Also, if you are running very old firmware you might need to update it (and also switch your readynas account over to SSO).
https://kb.netgear.com/30671/ReadyCLOUD-to-MyNETGEAR-Single-Sign-On-FAQ
