iCone
Sep 02, 2014Aspirant
/dev/md0 at 100%
Hi, While moving big files my Readynas' /dev/md0 got full, the unit is functional but want to know how can that be either cleaned up or at least reduce it's size. Filesystem 1K-blocks...
Sep 02, 2014Guru - Experienced User
Delete all logs for a start. Don't try to download them, I think you are lucky to have a unit that still works at all.
I suspect you moved stuff into the OS partition with ssh? If so, delete it.
One other option is to backup all data immediately, and then do a factory reset (which will require you to rebuild the NAS and restore from backup).
You can also contact support if you purchased new (you have a 3 year warranty). Though if you did this with ssh, they might deny support. Still its worth a try.
