iCone
Sep 02, 2014Aspirant
/dev/md0 at 100%
Hi, While moving big files my Readynas' /dev/md0 got full, the unit is functional but want to know how can that be either cleaned up or at least reduce it's size. Filesystem 1K-blocks...
mdgm-ntgr
Sep 02, 2014NETGEAR Employee Retired
du can help to find what is using the most space.
The logs are under /var/log
You may wish to do e.g.
Overwriting the log with an empty file rather than deleting it.
Backing up your data and doing a factory reset would be a good solution. However it would be advisable to free up some space from /dev/md0 before backing up your data.
# echo "" > /var/log/logname.log
