iCone
Sep 02, 2014Aspirant
/dev/md0 at 100%
Hi, While moving big files my Readynas' /dev/md0 got full, the unit is functional but want to know how can that be either cleaned up or at least reduce it's size. Filesystem 1K-blocks...
Sep 04, 2014Guru - Experienced User
Start at the top, and look at the overall size of the various folders (\var, \etc, ...) To see what they are, just
Then work down with "cd" until you find where the files are.
This should only take a couple of minutes, the folder structure is not that complex.
cd //Folders that are links will have a -> \c\sharename at the end, you can ignore those. But look at the others.
ls -l
du /foldername -s -htells you how much space is taken up by that folder. Use "du . -s -h" if you are already in the folder.
