daghastly1
Apr 20, 2008Aspirant
DHCP Reservations
I just want to make sure. My ReadyNAS cannot do DHCP reservations correct? Basically I want one of my computers to get the same IP every time it connects to the network. Thank you.
dbott67
Apr 21, 2008Guide
I did a little research on the DHCP server & it appears as though it's based on UDHCP (http://udhcp.busybox.net/). As far as I can tell, the version included with the ReadyNAS does not support static reservations (see quote below). You could increase the lease time from 900 to 864000 seconds (15 minutes to 10 days).
Perhaps you can add this to "Feature Request".
Anyhow, here are some of the specifics for the ReadyNAS.
Path to config file on ReadyNAS:
My current settings (with DHCP disabled):
Sample config file showing various options (from http://udhcp.busybox.net/udhcpd.conf):
From http://forum1.netgear.com/showthread.php?p=105292
-Dave
/etc/default/config/etc/udhcpd.conf
start 192.168.168.1
end 192.168.168.167
interface eth0
opt dns
opt subnet 255.255.255.0
opt router 192.168.168.168
opt domain
option lease 900
# Sample udhcpd configuration file (/etc/udhcpd.conf)
# The start and end of the IP lease block
start 192.168.0.20 #default: 192.168.0.20
end 192.168.0.254 #default: 192.168.0.254
# The interface that udhcpd will use
interface eth0 #default: eth0
# The maximim number of leases (includes addressesd reserved
# by OFFER's, DECLINE's, and ARP conficts
#max_leases 254 #default: 254
# If remaining is true (default), udhcpd will store the time
# remaining for each lease in the udhcpd leases file. This is
# for embedded systems that cannot keep time between reboots.
# If you set remaining to no, the absolute time that the lease
# expires at will be stored in the dhcpd.leases file.
#remaining yes #default: yes
# The time period at which udhcpd will write out a dhcpd.leases
# file. If this is 0, udhcpd will never automatically write a
# lease file. (specified in seconds)
#auto_time 7200 #default: 7200 (2 hours)
# The amount of time that an IP will be reserved (leased) for if a
# DHCP decline message is received (seconds).
#decline_time 3600 #default: 3600 (1 hour)
# The amount of time that an IP will be reserved (leased) for if an
# ARP conflct occurs. (seconds
#conflict_time 3600 #default: 3600 (1 hour)
# How long an offered address is reserved (leased) in seconds
#offer_time 60 #default: 60 (1 minute)
# If a lease to be given is below this value, the full lease time is
# instead used (seconds).
#min_lease 60 #defult: 60
# The location of the leases file
#lease_file /var/lib/misc/udhcpd.leases #defualt: /var/lib/misc/udhcpd.leases
# The location of the pid file
#pidfile /var/run/udhcpd.pid #default: /var/run/udhcpd.pid
# Everytime udhcpd writes a leases file, the below script will be called.
# Useful for writing the lease file to flash every few hours.
#notify_file #default: (no script)
#notify_file dumpleases # <--- usefull for debugging
# The following are bootp specific options, setable by udhcpd.
#siaddr 192.168.0.22 #default: 0.0.0.0
#sname zorak #default: (none)
#boot_file /var/nfs_root #default: (none)
# The remainer of options are DHCP options and can be specifed with the
# keyword 'opt' or 'option'. If an option can take multiple items, such
# as the dns option, they can be listed on the same line, or multiple
# lines. The only option with a default is 'lease'.
#Examles
opt dns 192.168.10.2 192.168.10.10
option subnet 255.255.255.0
opt router 192.168.10.2
opt wins 192.168.10.10
option dns 129.219.13.81 # appened to above DNS servers for a total of 3
option domain local
option lease 864000 # 10 days of seconds
# Currently supported options, for more info, see options.c
#subnet
#timezone
#router
#timesvr
#namesvr
#dns
#logsvr
#cookiesvr
#lprsvr
#bootsize
#domain
#swapsvr
#rootpath
#ipttl
#mtu
#broadcast
#wins
#lease
#ntpsrv
#tftp
#bootfile
March 18th, 2008, 01:25 AM
yschandra yschandra is offline
Junior Member
Post Re: Problem with DG834G v4 address reservation
Exactly same problem exists with all version of DG834GT firmware including latest V1.02.14. I found that the problem is with the udhcpd version used which is 0.9.7. This version doesn't have a feature of static leases (reserve IP based in MAC). I pulled out SVN snapshot of udhcpd which has static leases feature and compile and created custom firmware and tested, it works properly.
If my guess is right DG834G v4 firmware base is also using udhcpd which doesn't support this feature which Netgear does not seem have tested properly.
If some one feels adventure enough to pull the sources and try to building firmware with new udhcpd I am there to help.
-Dave
- Feb 20, 2022Retired_Member
