bstuke
Aug 24, 2021Aspirant
Did Gmail access for alerts quit working again?
Running an Ultra 6 with 6.10.5 firmware. I have "less secure" turned on, as well as 2 step and use your phone turned off. I still get an error message. I updated the password so I know they are t...
Aug 24, 2021Guru - Experienced User
I still get an error message. I updated the password so I know they are the same and still nothing.
It is working on my Pro 6 with no problem. SMTP service is smtp.gmail.com, port is 465, and Use TLS is checked. From address is identical to my account name (including gmail.com)
bstuke
Thanks for the feedback. I think my port is incorrect. This unit has been powered down and idle since before Covid. I am not in front of it now, but I think it is set for 587, or something like that.
- bstukeAug 25, 2021Aspirant
So far no luck. I cleared it out, and clicked on Google, and it let me set it up. I still get an error sending a test message! I turned of 2 step validation and made sure less secure is turned on.
I'm stumped. Maybe there is a port blocked or something. I am running WAP, and letting the modem handle DHCP. I did turn off Firewall on my modem.
Crazy.
- StephenBAug 26, 2021Guru - Experienced User
The user and from fields also need to match exactly, and both need to include Gmail.com
- bstukeSep 01, 2021Aspirant
StephenB wrote:
bstuke wrote:So far no luck. I cleared it out, and clicked on Google, and it let me set it up. I still get an error sending a test message!
I did make sure that was correct as well. I really think it is something with my routers. I am having another problem with WIZ bulbs connecting as well. I have turned off all firewalls and such, but still nothing.
