martin9911
Sep 01, 2016Aspirant
Difference in available storage space between WebGUI and Finder(AFP)
Running 6.5 A couple of weeks ago I removed a "private time machine" allocating roughly 500Gb. The avaialabe storage in the WebGUI differs about 500Gb compared to what I can see in Finder, mounting ...
- Sep 12, 2016
The NAS uses base 2 (like most PCs) whereas the Mac uses base 10. So you will get a larger number on your Mac but the amount of free storage is the same.
Also the Time Machine tab won't let you set a quota that is as large as all of the remaining space (it's not advisable to completely fill a volume).
mdgm-ntgr
Sep 01, 2016NETGEAR Employee Retired
What numbers do each report? And how much space is on the volume?
martin9911
Sep 09, 2016Aspirant
A balance did not fix it...
- martin9911Sep 09, 2016Aspirant
I´m doing a huge sorting of my data, all across my computers, external drives and the NAS.
This problem came when i removed a private time machine and I´ll soon be doing it again.
Can I fix this some way and how do I remove private time machine the right way so this does not happen again?
/Martin
- mdgm-ntgrSep 09, 2016NETGEAR Employee Retired
You may wish to update to 6.5.2.
Can you also send in your logs (see the Sending Logs link in my sig)?
- martin9911Sep 11, 2016Aspirant
Upgraded to 6.5.1, which is the latest available update for me.
I have found differences also within webgui.
Se attached files.
Sending you logs soon.
