nasageek
Nov 10, 2011Aspirant
Disable Unused Services (CUPS for instance)?
Is there any way to turn off unused daemons in the ReadyNAS Duo? My IT security department has flagged my NAS as having a vulnerability in CUPS. That's fine, I don't use it as a print server, so I w...
nasageek
Nov 14, 2011Aspirant
I will let you know what vuln they're seeing when I hear back from them.
I did a quick fancy find looking for cups calls: find /etc/init.d -type f | xargs grep -i cup
and the only references are in cupsys and rc3 (and powerdown which just deletes entries in the spool)
so it looks like if I just comment out the startup line in rc3 that would probably keep cups from being loaded on startup.
I assume the rc3 is updated when the firmware is (or is it not?) so I would just have to redo that comment every time I upgrade the firmware but that isn't any real hardship.
