useruser22
Jun 09, 2017Aspirant
Disaster after updating 6.4.2 to 6.7.4 help
After updating from 6.4.2 to 6.7.4 lost lun (share), that was attached to proxmox with one big VM. With LUN group is all ok, it exists, but there no LUN in a group, server couldnt connect to 2TB ...
- Jun 12, 2017
So I connected to storage by SSH and saw that there is LUN share, that I can't delete it (always got error), but there are no files in this folder (no simple files and no configuration files).
I think updating from 6.4.2 to 6.7.4 has really big issues with iSCSI working and failing. In the internet I found some problems very near like me.
I want to thank you for your pleasure to help me on weekend.
But there is strange how you don't saw this luns, because directory with some configuration files is there.
In updating there was no warning that doing this update could do any bad affect to my system or files.
It looks like that there is a LUN, ant it is somhow LOCKED, but new updated system doesnt see it.
From first look to NETGEAR goods in server room few months ago it little bit scared me, because i'm often working with IBM, Lenovo, Dell hardware. But i thought it i'll be ok, try to work with it.
But after this incident sadly but I couldn't recommend this name for any computers specialist, and must to do hardware changes to more responsible hardware and software manufacturers, than NETGEAR.
It's very simple to say that user is responsible for it's data, but this is not simple CD, and updates are not just for fun, but firstly for security. So how oher time I could expect to do updates, hope for better security bug fixes and better storag stability and get my system down for good hopes?
useruser22
Jun 10, 2017Aspirant
I tryed to create new lun on existing group and got ant error 21001020001. There is another problem? Maybe this version have any limatations to lun size, so this version dont see existing 2tb lun?
Can you check again it? Thank you..
useruser22
I couldnt crate any size of lun...
I have configuration backup before update, could it help for you?
- mdgm-ntgrJun 10, 2017NETGEAR Employee Retired
On ARM units there's an 8TB limit for the size of LUNs.
- useruser22Jun 11, 2017Aspirant
Semething goes wrong,
I could create LUN of any name, but when i creating lun with name that was 2tblun with vm, i get ant error, and could not create lun, if i change luns name its ok.
Any ideas?
- useruser22Jun 12, 2017Aspirant
