TW77
Feb 21, 2013Aspirant
Disk Failing
HI All, I have a ReadyNas Duo, running 2 x 2TB drives in x-raid configuration. For a while now I have been getting the following type notifications. "Access to the disk on channel (??) is produ...
mdgm-ntgr
Feb 21, 2013NETGEAR Employee Retired
The WD disk is failing, I think. You could hook the drive up to an internal SATA port in your PC and test it using WD LifeGuard Diagnostics.
Also note that there is a firmware update available for your SeaGate disk. See http://www.readynas.com/forum/viewtopic.php?f=24&t=64510
Before doing a firmware update on the SeaGate disk you should backup your data. You would need to hook the drive up to an internal SATA port in your PC to do the upgrade.
