backstr
Apr 18, 2011Aspirant
Disk failure detected.
Hi, I have a new Ultra 4 (running 4.2.16). A few hours after sync finished on the second disk (only two installed) I got a disk failure warning. Both drives in the array were new (they had been in ...
Jedi_Knight
Apr 18, 2011Tutor
I would suggest testing the disk test with disk test tool from disk manufacture on those failure disks. Could you tell us Make/Model/Size/Firmware of the drive you are using?
