bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
bluewomble
Mar 16, 2011Aspirant
I ran the extended disk test as you suggested... it ran overnight (and then I guess it finished it's resync)... it hasn't reported any problems. Can I see the results of the test in any of the logs?
Everything seems to be working fine now.
Should I ignore the problems I had with disk 2 and 4, or are there other tests I should run?
