bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
Sciri
Mar 17, 2011Aspirant
dataactive wrote: I'm also having problems with disk 4. When I try fdisk -l /dev/hdi nothing happens. Is there another command that I can use to list all of the devices? Perhaps it's not listed as hdi?
Yes, just run fdisk -l with no arguments.
bluewomble wrote: Everything seems to be working fine now.
Should I ignore the problems I had with disk 2 and 4, or are there other tests I should run?
Have you experienced any more issues with this setup or have you been running smoothly since your initial two failures? My ReadyNAS Ultra 6 Plus with 6x ST2000DL003-9VT166 (CC32) experienced a similar failure. /dev/sdb disappeared on hour 42 of operation. Health listed the Status as Dead (not Failed) with the SMART+ button grayed out, and Volume Settings had a missing entry with no Locate button.
Pulling and reinserting the drive did nothing. Inserting a fresh drive did nothing. The disk interface was just dead. I cold rebooted the ReadyNAS, the disk happily resynced, and SMART reported no errors.
