bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
imlucid
Apr 06, 2011Aspirant
mdgm wrote: The disk could still be failing/dead. I would suggest backing up your data, then powering down and running the "Test Disks" boot option: http://home.bott.ca/webserver/?p=252
Thanks mdgm, I'll give that a shot tonight. I've run it through the various standard boot tests available through the Web UI but haven't tried this yet...
Kevin
