bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
imlucid
Apr 07, 2011Aspirant
CitizenPlain wrote: Yeah. I'm with Kevin & BlueWombie. Doesn't seem like a regular failure to me either and we've all got the same setup (Ultra 6 Plus and the same drives.) The drive keep working just fine and without errors after they're reinserted and checked.
Are you guys also all using OSX? I wondered if it was some sort of weird conflict with doing a file transfer and Time Machine trying to back up at the same time. I thought I observed that on my second failure earlier (was using the machine when the drive died -- other two times I wasn't in the room when I got the alert), but I can't tell if it was coincidental or not.
I'm using OSX (Leopard and SnowLeopard).
I do have Time Machine backups set up to this NAS as well (but not to my mirrored backup NAS)... I have no idea if TM was trying to run at the time but have seen TM errors.
Kevin
