bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
imlucid
May 09, 2011Aspirant
Hmm, interesting new developments...
So after drive reported failure I shutdown, pulled drive, replaced and booted.
Drive still shows missing so I do the same steps again waiting a bit longer and on boot it starts resyncing the drive. So far so good.
After it was around 1.6% done or so, I checked to see if I could mount cifs via finder, no problem.
I tried to load the frontview web admin and at first it wouldn't load, but after a couple of tries it loads but doesn't fill in any text. Then the drive's fans go on full blast and what appears to be something like a progress bar on the LED on the front of the NAS starts flashing from left to right a few times and the NAS then reboots...
Interesting.
So I do the same steps again and once again right when I'm trying to load the web UI, the server reboots again with same symptoms...
I'm now going to leave it alone as it is trying to resync again (3rd time a charm?).
Kevin
Interesting.
Kevin
