bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
PiddeP
Aug 11, 2011Aspirant
I've experienced the exact same problem, but with another Seagate model (ST31500341AS). They worked flawlessly with my Duo but when I switched to an Ultra 2 the problems started.
My system.log is filed with cycles like this one:
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1: limiting SATA link speed to 1.5 Gbps
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: failed command: FLUSH CACHE EXT
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 0
Aug 11 10:48:06 nas-8B-21-2C kernel: res 40/00:01:00:4f:c2/00:00:00:00:00/00 Emask 0x4 (timeout)
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: status: { DRDY }
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1: hard resetting link
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: configured for UDMA/133
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: retrying FLUSH 0xea Emask 0x4
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1.00: device reported invalid CHS sector 0
Aug 11 10:48:06 nas-8B-21-2C kernel: ata1: EH complete
Two days ago disk 2 turned "dead"/grey in Frontview, but came back alive after I pulled it out, rebooted and then put it back in. After a few hours it hade re-synced.
This has now happened again, but now disk 2 is still showing in Frontview as dead, without being present in the system! I can't make the system identify the slot as empty, and then re-sync as I insert the drive.
What should I do? Could a reboot with both of the inserted do any harm?
Cheers,
Peter
Cheers,
Peter
