bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
opt2bout
Dec 01, 2011Aspirant
I have a RMA'd chasis, same drive ST2000DL003 which I only bought because of the HCL. I have two in this unit, and they will alernate failed status randomly whenever I reflash the unit. (note that just removing and adding the drive back into the chasis doesn't do it for me, I have to power down and up before it adds the "failed" drive back into the array. Then after a couple of Time Machine backups, one of the new ST2000DL003 drives fail.
I too am going to try the latest beta. I shied away from this because support won't support betas, but since 4.2.19 doesn't fix the problem, and I have an open case like the rest of you, what do I have to lose??!?
I did get an update from the support engineer back on 11/10 with a link to Seagate's forums ????
http://forums.seagate.com/t5/Barracuda- ... 154/page/2
