bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
PiddeP
Mar 16, 2012Aspirant
bokvast wrote: Got an answer from a l3 that they are working on a fix and it is expected to arrive in Q1 2012
Soon Q1 has passed without a fix being released. I have installed the latest update but no luck - the problem persists on my Ultra 2.
I have got a feeling that the error only exists on some layers - for instance the leds on the front panel light up as if both disks are online and redundant, and each time I remove the faulty disk, shut down, replace it and power up again I receive the status message "Data volume will be rebuilt with disk 1". Still the Frontview displays the disk as dead.
When I connect the drive to my PC it is possible to access without problems...
