bluewomble
Mar 13, 2011Aspirant
Disk Failure Detected...
I've recently purchased a ReadyNAS Ultra 6 along with 6 2 Tb Seagate ST2000DL003 disks (which are on the HCL). I've set up the NAS in a dual redundancy X-RAID2 configuration and have starting copyi...
jrpNAS
Jun 25, 2012Aspirant
Seagate's 2TB Green disk have Flush Cache problem. If you turn off the disk cache, then the NAS are more reliable.
My Ultra 4 has worked of February 22 to May 26, without any problems. I enable to the write cache May 21 and May 26 one disk was "die".
After volume rebuild I turn write cache off and NAS is still running without problems.
In February I reghance one disk because Seatools find several bad MBA's. That disk died many times even if write cache was off.
