Friedenthal
Jan 14, 2012Aspirant
Disk lights out of sync
I have a NV+, which I am just setting up. As part of the process I upgraded The firmware to 4.1.8. Now both RAIDar and the unit itself insist the only disc is in slot 2, when it's actually in slot ...
mdgm-ntgr
Jan 14, 2012NETGEAR Employee Retired
That is odd.
To do factory reset you:
1. Power down
2. Press and hold reset button
3. Turn NAS on via power button
4. Keep holding reset button. The disk LEDs will flash twice. Once after 5 seconds (status "5: OS Re-install" will show on LCD) and a second time after 30 seconds (something like "30: Factory Default" will show on LCD). Release after the second flash of the disk LEDs.
1. Power down
