ErwonB
Sep 22, 2018Aspirant
Disk not recognized
Hi,
I was trying to setup my readynas but my disks are not recognized.
I'm able to see the NAS on the network (with no disk though)
I tested my two disks and they are healthy.
Is it a connec...
Marc_V
Sep 23, 2018NETGEAR Employee Retired
Hi ErwonB
Welcome to the Community!
Are you getting Corrupt or Used disk error message?
Have you tried accessing the Boot menu and doing a Factory reset with the disks? If you had done this and you still experience the same issue, you may want to try a different disk instead or you still have warranty for your NAS, contacting NETGEAR Support is also a good way to have this resolved as there might be an issue with the chassis or the OS itself.
ReadyNAS: Accessing the Boot Menu
Hope this helps!
Regards
ErwonB
Oct 18, 2018Aspirant
I was able to completely wipe out my disks but the problem remains the same when I try to power on my NAS the blue power and the green LED are just flashing constantly.
So I guess my NAS is dead :/
