mlupo
Jan 27, 2017Aspirant
Disk replaced hot swap, resynced, volume degraded
I replaced a disk drive with the exact same drive model. The NAS resynced the drive, but volume is still showing as degraded. Both drives show status as green. OS 6.6.1
Jan 27, 2017Guru - Experienced User
Download the logs and look in mdstat.log. See if the new drive is marked as a spare.
mlupo
Jan 29, 2017Aspirant
There are no spare drives.
Also, when I attempt to back up to the drive using Acronis, it gives me a network disconnected error. Using data files on ReadyNAS work fine without any network issues.
- StephenBJan 29, 2017Guru - Experienced User
Any hint in mdstat on what the volume is degraded then?
- mlupoJan 29, 2017Aspirant
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid5 sda3[0] sdb3[2]
5850829568 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/2] [U_U]
md1 : active raid1 sda2[0] sdb2[1]
523712 blocks super 1.2 [2/2] [UU]
md0 : active raid1 sda1[0] sdb1[2]
4190208 blocks super 1.2 [3/2] [UU_]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Mon Mar 2 19:11:47 2015
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 3
Total Devices : 2
Persistence : Superblock is persistentUpdate Time : Sun Jan 29 14:58:29 2017
State : clean, degraded
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0Name : 2fe519e1:0 (local to host 2fe519e1)
UUID : 48ff1028:6a05d569:f8e9a1f6:2db232a7
Events : 108312Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
2 8 17 1 active sync /dev/sdb1
4 0 0 4 removed
/dev/md/1:
Version : 1.2
Creation Time : Thu Jan 26 10:16:41 2017
Raid Level : raid1
Array Size : 523712 (511.44 MiB 536.28 MB)
Used Dev Size : 523712 (511.44 MiB 536.28 MB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistentUpdate Time : Fri Jan 27 14:36:21 2017
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0Name : 2fe519e1:1 (local to host 2fe519e1)
UUID : dc2be79b:e4e95d64:bc1e5cb1:9ec216ee
Events : 19Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
/dev/md/data-0:
Version : 1.2
Raid Level : raid5
Array Size : 5850829568 (5579.79 GiB 5991.25 GB)
Used Dev Size : 2925414784 (2789.89 GiB 2995.62 GB)
Raid Devices : 3
Total Devices : 2
Persistence : Superblock is persistentUpdate Time : Sat Jan 28 15:15:12 2017
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0Layout : left-symmetric
Chunk Size : 64KName : 2fe519e1:data-0 (local to host 2fe519e1)
UUID : 18ac651b:849da6a1:c7846d8c:bc2c0f72
Events : 10257Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
2 0 0 2 removed
2 8 19 2 active sync /dev/sdb3- StephenBJan 29, 2017Guru - Experienced User
mlupo wrote:
/dev/md/data-0:
Version : 1.2
Raid Level : raid5
Raid Devices : 3
Total Devices : 2
Persistence : Superblock is persistentWhat ReadyNAS model is this?
Were there ever three disks installed?
