janpeter1
Oct 13, 2021Luminary
Disk test of RAID-1 takes more than 30 hours - something wrong?
Hi I am in the process of upgrading my RAID1-disk pair on RN314 system. Before change one of the disks I do "Disk test" from the NAS. It takes very long time and makes me a bit worried, although...
- Oct 19, 2021
I just want to repor that the final resync of "empty" last half of the 8TB was completed without any problem. All disks are ok. Took 26 hours the last part.
The somewhat long time is partly due to regular but small time machine backup from one computer that I did not turn that off during resync. That backup was however done to another disk on the same NAS but took likely some CPU resources.
Thanks for your helpful support!
Oct 13, 2021Guru - Experienced User
janpeter1 wrote:
I am in the process of upgrading my RAID1-disk pair on RN314 system. Before change one of the disks I do "Disk test" from the NAS.It takes very long time and makes me a bit worried, although from the data I see and understand the RAID-system is found healthy so far. I have now run the disk test for about 30 hours. During the disk test I put the fan on "cool" and keep the CPU temp < 50C.How long should I let the disk test go on?
I'd let it complete, since it does sound like there could be an issue, and if a disk is causing the problem then it should be replaced first.
janpeter1 wrote:
How long should I let the disk test go on?Something I can check to understand that the test disk process is running well?
You could check the log page (chosing both disk and volume as filters).
If ssh is enabled, you could also try smartctl -x /dev/sda and smartctl -x /dev/sdb
janpeter1
Hi agaain,
The disk test completed after 33 hours and 3 min (on my RND314 bought 2015).
The two disk are
- WD 4 TB - 64 MB cache - 5400 rpm - WD40EFRX - bought 2015 August
- WD 8 TB - 256 MB cache - 5400 rpm - WD80EFAX - bought 2021 February
The RAID-1 had only 10% left now (of the 4TB) and high time to upgrade the 4TB disk.
After the test the overview showed the RAID-1 still as healthy
And in Perfromance view hoovering over the green knobs for each disk
I see that there an no error in any of the two disks.
Downloaded the System_log that contains a lot. I guess the file disk_info.log is of main interest.
That file shows also no errors. Here is a btrfs.log that is not too long but does not seem
to contain something worrisome. Cannot find a date here though.
I do tno think I have ssh-enabled. Many years ago on other computers I used ssh and no it is powerful tool.
Have rudimentrary Linux skills and could manage simple check ups if needed.
But what I see make me less worried now. Still the very long disk test bring questiona marks also for you, right?
One reason might be that the disk was that full, or? Still I though the disk test was without concern of what was on the disk.
Another reason for the long time might be that has been a poorly matched RAID-1 pair of disk, but not sure.
I wait for your response, before I exchange the 4 TB disk to the newly bought and tested 8TB WD80EFBX disk (7200 rpm though).
And I plant to do that echange of disk as a hot-swap, based on earlier recommendations here on the forum.
Thanks!
- StephenBOct 14, 2021Guru - Experienced User
The two disk are
Still the very long disk test brings question marks also for you, right?
My RN524 with 4 WD80EFAX drives completes the disk test in about 21 hours. I'd expected the RN314 to complete more quickly, especially with fewer disks. But the test is run in the background, so the running time would depend on what else the NAS is doing.
... And I have done the procedure to back up everything
Since you have an up to date backup, it is safe to proceed. I agree hot-swapping is the right method.
- janpeter1Oct 14, 2021Luminary
Hi again,
I have moved the new disk to the RAID-1 (after DESTROYING the temporary volume I made for test purpose on the new disk).
The resync goes on and now after about 2 percen done the time estimate seems to stabilize around 15 hours. Seems ok.
The fan is also turned up to "Cool".
The NAS does not do much this week, but occasionally do incremental backup of my or my wifes Macs.
So the work-load I do not think explain the long time to do Disk test.
For Netgear it would be good if they could include a progress bar in Disk test as they have for Resync.
At least you see that something happens and there is some progress, and at a later stage i guess the reamining time estimate
becomes rather good.
Within a few months I think I will buy another 7200 rpm disk so RAID-1 have the same disks.
The 5400 rpm disk I will have use for to take backups for our Macs here.
Can you say something about the noise level of 7200 rpm compared to 5400 rpm disks?
Noticeable, when you have just a RAID-1?
WD80EFBX: 27 dBA Idle/29 dBA Seek
WD80EFAX: 27 dBA Idle/29 dBA Seek
WD40EFRX: 25 dBA Idle/28 dBA Seek.
So the WD80EFBX model has the same noise spec as the WD80EFAX you already have - and a very slight increase in the noise spec over the WD40EFRX.
Note the WD80EFAX you already have is 7200 rpm, not 5400. There is a footnote in the datasheet ( https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/internal-drives/wd-red-plus-hdd/product-brief-western-digital-wd-red-plus-hdd.pdf ): Actual Spindle Motor Rotational Speed for this model is 7200 RPM; though ID Device may report 5400 to reflect previous Performance Class designation.
Not sure what to make of that. There is some press on it here https://www.extremetech.com/extreme/317327-western-digital-changes-its-reported-drive-speeds-to-reflect-reality
