stevevandegaer2
Aug 11, 2019Tutor
Disk test running 10 days already
Hello, I'm running a readynas with firmware 6.10.1 On august 1 I started a disk test and it is still running now on the 11th. I guess this isn't normal. What should I do? Is it safe to reboot?...
stevevandegaer2
Aug 11, 2019Tutor
Last night had to reboot after the device became unresponsive when I activated file search.
Should I try the disk test again or do something else first?
Aug 12, 2019Guru - Experienced User
One possible reason for the very long test time is that you might have a failing disk. I suggest downloading the log zip file and looking in disk_info.log. Also look for disk related errors in kernel.log
You might also want to use ssh, and run smartctl -x
- stevevandegaer2Aug 12, 2019Tutor
Not seeing any error in either log file.
Started the disk check again, hoping I will get some result this time
smartctl -x
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.178.x86_64.1] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
ERROR: smartctl requires a device name as the final command-line argument.
Use smartctl -h to get a usage summary
- StephenBAug 12, 2019Guru - Experienced User
Sorry, I assumed more knowledge than you have.
You need to include the device name for each disk. So for the first disk you use
# smartctl -x /dev/sda
Repeat using sdb for disk 2, and so forth.
One thing to look for is the "Extended Comprehensive Log" section. Here's a snippet from my own system. "UNC" means "uncorrected error". Not all disks will have this section, but it is helpful when they do.
root@NAS:~# smartctl -x /dev/sdc smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.178.x86_64.1] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === ... === START OF READ SMART DATA SECTION === ... SMART Extended Comprehensive Error Log Version: 1 (6 sectors) Device Error Count: 12 CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 12 [11] occurred at disk power-on lifetime: 36166 hours (1506 days + 22 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 0c 27 df 40 40 00 Error: UNC at LBA = 0x0c27df40 = 203939648 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 80 00 c8 00 00 0c 27 df 40 40 08 1d+08:15:46.204 READ FPDMA QUEUED 60 00 08 00 c0 00 01 06 34 36 98 40 08 1d+08:15:46.163 READ FPDMA QUEUED 60 00 80 00 b8 00 00 0c 27 e4 40 40 08 1d+08:15:46.146 READ FPDMA QUEUED 60 00 80 00 b0 00 00 0c 27 e9 40 40 08 1d+08:15:46.123 READ FPDMA QUEUED 60 00 80 00 a8 00 00 0c 27 ee 40 40 08 1d+08:15:46.094 READ FPDMA QUEUEDErrors in this section might not mean the disk needs to be replaced. But if you are seeing errors that happened during your disk test, then it might help you isolate your problem. If you do see some, the next step is to power down the NAS and test the disk(s) in a Windows PC using vendor tools - lifeguard for Western Digital; seatools for Seagate. If they pass, put them back in to the NAS (in the same slot) before you power it up.
