Digital999
Nov 16, 2019Luminary
Disk upgrade when ond drive is failing
RN31200 with two 1TB drives running in XRaid mode. One of the drives has failed. I want to replace the drives with a larger set -- 2 or 4 TB pair Article ID: 21415outlines a procedure that says r...
Nov 17, 2019Guru - Experienced User
Digital999 wrote:
Is it truely that simple or are there some 'hints/tricks' that would help?
It is about that simple. Though it is recommended to back up your data first, especially since one disk has already failed.
You'd hot-swap the failed disk first (removing it, and inserting a new blank one with the NAS running). After the resync completes (which will take quite a while), you hot-swap the second. That will resync in two steps (and the volume won't expand until the second step).
Personally I like to test the new disks in a PC first (using Lifeguard for Western Digital; SeaTools for Seagate). If you do that, then don't format them.
FWIW, I recommend using NAS-purposed disks for your NAS (Seagate Ironwolf or WD Red drives).
- Digital999Nov 17, 2019Luminary
Thank you for the reassuring response. It is always comforting to hear the voice of experience.
What I had previously missed is replacement while device is running -- I would have turned off since I am sort of a careful approach person.
We have many units across the country -- they will all need proflactic replacment/upgrade over the next year or so. This is a pilot of the process that we hope to accomplish with non-technical personnel.
- StephenBNov 17, 2019Guru - Experienced User
You can also replace the drive with the system turned off, but I always recommend hot-swapping or hot-insertion instead. The reason is that when the system is on it can easily detect the removal and insertion. When the system is off, it needs to figure out what has changed.
You do need to be more careful to replace the right drive when the system is turned on, as bad things can happen if you accidently remove the wrong one.
- Digital999Nov 18, 2019Luminary
As in most things, one question leads to another.
Seagate touts their IronWolf Health Management software/capability.
Looks interesting and like it would be a good managment tool as drives are replaced over the next year in our distributed environment.
Unfortunately Netgear is not listed as a 'partner'. Any visibility on if/when that might happen?
