davidr1
Oct 29, 2016Luminary
Disk Useage Critical (again?)
Hi, OS 6.6.0 2x1TB WD Red drives (on HCL list) A nasty warning this morning: System volume root's usage is 91%. This condition should not occur in normal conditions. Contact technical support....
- Oct 30, 2016
You likely will run into issues getting support since you are running OS6 on a legacy NAS. Can you ssh in? If so, please run df . -h when you get in, and post the results.
FWIW, I've been told that Netgear Data Recovery Services are available to folks running OS 6 on legacy.
Oct 30, 2016Guru - Experienced User
FramerV
Oct 30, 2016NETGEAR Employee Retired
Thank you for this StephenB, I have confirmed that you will be denied of the support for the Legacy NAS running on OS6 but we can offer the data recovery.
If you will be considering data recovery, you can check the link below:
ReadyNAS Data Recovery Diagnostics - Scope of Service
