kamezvas
Jul 29, 2013Aspirant
Disks All OK (Green) but Volume is blank/missing
I have been using the readynas NV+ 2 for a few months without a problem but I hit a few error message when trying to configure it for TimeMachine use. Shortly after the volume disappeared but every...
kamezvas
Jul 30, 2013Aspirant
Hi Guys,
Thanks for the replies, to answer your questions:
Can you access your data?
- not through the NAS, I have yet to connect the drives to a PC.
Have you rebooted the NAS?
- I have rebooted many times all with the same result. no volume detected. The errors I get in the log are that the shares cannot be found.
Do you have a backup?
- Files are backed up through CrashPlan offsite. Any files that are not backed up can be replaced easily.
I have tried looking at the logs but not sure where to start I'm afraid. I find it strange that the whole volume failed. I expected to just see a single drive fail and the volume stay intact.
I did notice that on the first disk there is a Read Bad Sector 1 under the info link.
I do not have access to the NAS at the moment as I am at work, but I can upload the logs if you think it will help. I do not know what I am looking for.
