kamezvas
Jul 29, 2013Aspirant
Disks All OK (Green) but Volume is blank/missing
I have been using the readynas NV+ 2 for a few months without a problem but I hit a few error message when trying to configure it for TimeMachine use. Shortly after the volume disappeared but every...
vandermerwe
Jul 30, 2013Master
Im not sure if mdgm would sanction the following - see if he agrees.
If it is a raid volume:
Try powering down, removing disk 1 then booting without disk 1. If this fails as well, don't put disk 1 back without first powering off.
Do you have a spare disk to replace disk 1 if necessary?
You could also try ( with all disks in) an OS reinstall using the boot menu:
http://www.readynas.com/kb/faq/boot/how ... _boot_menu
