Rolliel
Mar 18, 2014Aspirant
Disks fail to spin down 3 weeks after upgrade
Perhaps coincidental.. Upgraded a ReadyNas duo v1 to 2 x 1TB Seagate drives (from "approved" list). All seemed fine after couple restarts (file operations, and media streaming fine) for 3 weeks or so...
Mar 19, 2014Guru - Experienced User
Of course the warranty is Seagate's not Netgear's. You can check warranty status from here: http://support.seagate.com/customer/en- ... jsp?form=0
Rolliel wrote: ...FWIW, the old drives were Seagate ST3750528AS, while the new ones are Seagate, ST31000340NS (chosen from the Netgear compatibility list, based on alleged 5 yr warranty + vibration "protection"; probably a naïve faith on my part)...
