StormyKnight
Jun 27, 2012Aspirant
DLNA - Samsung TV - Nfo files sort issue
ReadyNas Duo - Samsung Smart TV Installed ReadyDLNA 1.0.24.3 latest version Added my TV shows folder to the DLNA setup filtering on video files only Each Video file has a corresponding nfo file ...
Jun 27, 2012Guru - Experienced User
The NFO files aren't accessed directly by the Samsung - these files are being included in the ReadyDLNA scan, and put into its database. ReadyDLNA is based on MiniDLNA open source, there is a main link here: http://minidlna.sourceforge.net/
There are some config options in etc\minidlna.conf, but the comments have nothing listed related to NFO.
While an option to ignore nfo would be nice (and probably is easy to do), it seems better to me to fix the NFO files so they contain the title you want. Admittedly it is a lot of work - though the end result would be metadata that is more useful to you.
