StormyKnight
Jun 27, 2012Aspirant
DLNA - Samsung TV - Nfo files sort issue
ReadyNas Duo - Samsung Smart TV Installed ReadyDLNA 1.0.24.3 latest version Added my TV shows folder to the DLNA setup filtering on video files only Each Video file has a corresponding nfo file ...
StormyKnight
Thanks for the reply....
The issue is the nfo's are used for XBMC correctly....
i.e. the title has just the title, the season has just the season, the episode has just the episode......
DLNA is using the title instead of the filename, which I guess is fine for movies but not for episodes......
Ideally, I would like the DLNA to ignore the nfo's altogether, then I could (& have) named the filenames of the episodes & movies so they sort correctly....
Thanks for the link, I will look into that & do some research myself...
Cheers
Cheers
