StormyKnight
Jun 27, 2012Aspirant
DLNA - Samsung TV - Nfo files sort issue
ReadyNas Duo - Samsung Smart TV Installed ReadyDLNA 1.0.24.3 latest version Added my TV shows folder to the DLNA setup filtering on video files only Each Video file has a corresponding nfo file ...
StormyKnight
Jul 05, 2012Aspirant
howsk, looks like what you are getting is what I want......i.e. I want the DLNA server to ignore the nfo & just use the filename so that the samsung with just display the filenames in alphabetical order (movies fine & this will mean episodes will be in chronological order too).....
my nfo's are xbmc compatible so they contain a line <title>2012</title> for example....does you nfo contain a similar line?
