dgerson76
Feb 26, 2012Aspirant
DLNA disconnects with WDTV & Ultra2+
I upgraded from a DUO to an Ultra2+ recently. My setup has not changed- DLink DIR-655 and WDTV Live. Running latest version of ReadyDLNA. Everything is connected via cat5. With the DUO I had no...
Feb 28, 2012Guru - Experienced User
It could be related to buffer overrun in the router - the WD Live is 100 mbit, and the router doesn't appear to support 802.3x pause frames. The ultra is a lot faster than the duo, and the router might not have enough buffering. Try setting the ultra to 100 mbit (as a test) and see if the issue resolves. If it does, you might need to add a newer switch behind the router.
