ipb_uk's avatar
ipb_uk
DLNA rebuild - rescan
RNDP6000-v2 V6.10.8
Something is wrong with the dlna part on this nas. When the nas is rebooted it deletes the files.db and starts to rescan. What needs to be done to stop it deleting the file and rebuilding?
I've reinstalled the firmware (6.10.8), hoping that would reset what ever was wrong but no joy there.
it's running as /usr/sbin/minidlnad -S
What info should I get for you to help me resolve this?
Thank You.
  • schumaku's avatar
    schumaku
    Mid term, an update to v6.10.9 would be smarter (due to the fixes applied in the package handling) than re-update for hope-and-pray.
    If minidlnad does find errors from the previous run, it will re-do the re-scan from scratch. Have an eye in the related log if available FMI.
    • StephenB's avatar
      Just wonderiing - does the scan complete w/o error before the next reboot?
      • ipb_uk's avatar
        ipb_uk
        Ok so where do I get 6.10.9 from? The box was updated on the 6th June, it's now says it up to date!
        The nas was on for about 39 days and the files.db was 41.3 GB. On 16 July snapshot it was 38.6 GB.
        I can't find 'upnp-av.log' any place other than downloading the whole lot of logs. At the moment I can't tell if it had completed a scan. I rebooted it this morning at 2.50, it now 19.00 and after downloading the logs to get the upnp-av.log the first few lines are....
        -- Logs begin at Wed 2023-07-19 05:19:57 WEST, end at Wed 2023-07-19 14:33:15 WEST. --
        Jul 19 14:01:10 Pro minidlnad[2941]: Application transferred too few scanlines
ProSupport for Business
