jcon1
Feb 09, 2013Aspirant
DLNA Shares sporadically visible on PS3
Up until a few weeks ago, I had no issues with my video share showing up on my PS3. Since then, its been sporadic. When I hit Rescan Media files in frontview, it reappears on the PS3 for a few seconds...
Feb 18, 2013Guru - Experienced User
jcon wrote: ...I am not questioning you(well, I guess i am sort of, but I mean no disrespect!), but are you 100% positive data isnt wiped with an OS reboot/reinstall? I thought I read somewhere it would?...
OS Reinstall - does not destroy data, but does reset your admin password to factory default, and resets your IP configuration to DHCP.
Factory Default - destroys everything: add-ons, user configuration, and data.
