gos2610
Sep 06, 2021Aspirant
DNS for ReadyNAS 2304 and ReadyNAS 214 under macOS Big Sur
Hello, I have installed 2 NAS Storage Systems (ReadyNAS 214 & ReadyNAS 2304) on my Network. Both get there reserved IP address from a DHCP Server (my BINTEC Router). On my Windows Systems I can adr...
Sep 06, 2021Guru - Experienced User
This is a new one for me, although I am not a mac user.
Windows isn't appending the -1, -2 stuff - so I am thinking it might be something that Big Sur is doing.
One practical work-around is to use the reserved IP address instead of the host name. You could also put the proper name in the hosts file on the mac.
- gos2610Sep 06, 2021Aspirant
Hi StephanB,
It is clear that you can do it this way, but this is only a workaround and not a solution :smileywink:
So I hope for the soution ...+
Thanks
StefanG :-)
