nodoze
Jul 29, 2011Aspirant
Do 6Gb/s disks perform much better than 3Gb/s in the Ultra6?
I got 6 of the 2TB Caviar Green WD20EARS from the compatibility list to add to my new ultra6. I have been copying the data from my old nv+ to the new ultra6 and plan to upgrade the nv+ to new drive...
mdgm-ntgr
Jul 29, 2011NETGEAR Employee Retired
The Ultra 6 has SATA II ports. Anyway your disks don't even saturate SATA I. Faster disks will make a small difference but you should look at the disk RPM speed and reviews of it's performance.
