pcarey
Oct 01, 2017Aspirant
do_exit+890 error RN21400
trying to setup this NAS for the first time. It displays the error do_exit+890 4 new 2 tb discs. tried both network plugs. Lights are green but nothing is happening.
- Oct 02, 2017
got it to boot.
I had 4 discs in there. All with no data but two of them I used to boot an older Readynas Duo that I was unable to start. (that worked by the way) Aparently the new one didn't like those discs. After shuffling them around it started.
I'm going to leave it alone until the power button becomes solid and it cools down. Then I'll put it on the network and see if it runs correctly then slide the other 3 discs in.
mdgm-ntgr
Oct 02, 2017NETGEAR Employee Retired
Which firmware version did this unit ship with? Have you tried a direct-connection between your PC and the NAS?
pcarey
Oct 02, 2017Aspirant
not sure which firmware. It's not booting.
I'll try to plug directly into a computer and see if it boots.
- pcareyOct 02, 2017Aspirant
got it to boot.
