shhowz
May 29, 2018Aspirant
do_exit+9ac on shutdown
RN104 running latest firmware (6.9.3). No changes to system config or local network/environment conditions. System is presenting the following symptoms.
1) Power button does nothing. Normally, ...
May 29, 2018Guru - Experienced User
The first two issues are I think the most concerning.
Is the ReadyNAS still covered by it's warranty?
- shhowzJun 25, 2018Aspirant
The device is out of warranty, otherwise I would be raising a ticket with NG support directly.
I was getting some assistance from user 'mdgm' who asked me to enable remote support on the device which I did but there has been no further correspondence.
I've now reset the device to factory default and still get the same issue. I will try manually rolling back to an old firmware if possible but as it stands this device is toast. Less than 5 years old, pretty disappointing really.
