hezner1's avatar
hezner1
Tutor
Jun 09, 2022
do not see scrub completed in log - is it done?
I realized that I had not run the scrub on my ReadyNas 3220 (which is the main file server for our company) for a while and had not restarted it for a long while.  I decided to run the scrub and then...
  • Sandshark's avatar
    Sandshark
    Jun 10, 2022
    If you have SSH access, use btrfs scrub status /data.  If it says it didn't complete and isn't still running, try btrfs scrub resume /data instead of starting over.
ProSupport for Business
