hezner1
Jun 09, 2022Tutor
do not see scrub completed in log - is it done?
I realized that I had not run the scrub on my ReadyNas 3220 (which is the main file server for our company) for a while and had not restarted it for a long while. I decided to run the scrub and then...
- Jun 10, 2022
If you have SSH access, use btrfs scrub status /data. If it says it didn't complete and isn't still running, try btrfs scrub resume /data instead of starting over.
hezner1
Jun 10, 2022Tutor
Thanks StephenB. I'll give it a try either today after everyone leaves the office or tomorrow morning and will let you know what happens. I really do appreciate all the time that you and the other volunteers put into this forum. You provide a great resource.
Sandshark
Jun 10, 2022Sensei
- hezner1Jun 10, 2022Tutor
Thanks Sandshark. I do have SSH enable but have never used it. I'll give those commands a try. Hopefully that will clear out any issues. I'll let you know what happens.
- hezner1Jun 11, 2022Tutor
Sandshark, thank you much for the SSH suggestion and for giving me the commands to use. This reports that if finished with no errors.
Don't have a clue why it did not report that in the admin dashboard but this seems like we are in good condition. Now I'll feel more comfortable with restarting the NAS and then I'll replace one of the drives that as reported a couple of smart errors.
I really need to update my maintenance check list so this does not get so far behind.
I really want to thank both Sandshark and StephenB for their help with this and for all their contributions to this site over the years.
Take care, Pat
- SandsharkJun 12, 2022Sensei
That's a pretty big volume for a scrub to complete in that short amount of time. But it does say it completed.
And you're welcome.
