Laudz
Mar 15, 2018Aspirant
Does ReadyNAS OS implement SMB 3.1.1?
My client software has just been upgraded to accept SMB 3 connections. I was wondering what protocol level of SMB is supported in ReadyNAS and where it is displayed. I'm running 6.9.3 stable release....
- Mar 15, 2018
Hi Laudz
ReadyNAS OS 6 supports SMB protocol 3.0 by default.
Information regarding this might not be available in the GUI but if you are comfortable with SSH then members might be able to add tips on checking this.
Here is a link to the information I provided regarding the default protocol used by OS 6 Units.
Hope this helps!
Regards!
mdgm-ntgr
Mar 15, 2018NETGEAR Employee Retired
If you download the logs and look in packages.log you'll see the version of the samba package that we're using. You can also find this in the GPL
Note we do backport some changes from newer samba versions and from time to time update the package to a newer version.
SMB 3.1.1 support was added way back in samba 4.3.0 as stated in the Samba 4.3.0 - Release Notes
