davidr1
Jun 15, 2011Luminary
Doing one's own rsync and cron scripts
Hi,
As, IMHO, the Ultra's GUI interface is appalling, it does not give me the backup versatility I want wth rsync and cron jobs. (Ducking the flames)
Is there anything that would cause Frontview problems if I used my own rsync scripts and cron files?
David
David
- mdgm-ntgrNETGEAR Employee RetiredShould be fine. Create your own file in /etc/cron.d that points to your own script. You can look at /etc/cron/frontview-backup and see it uses cron entries and a vague idea of what layout you'd need to use in your cron file.
You won't obviously get the benefits of viewing and configuring jobs in Frontview or Frontview's email alerts about backup jobs and you won't get help with this from tech support.
May I ask what versatility that you're after is Frontview missing in regards to rsync and cron jobs? - davidr1LuminaryThanks mdgm,
Agreed - but I'm used to 'once set - forget'.won't obviously get the benefits of viewing and configuring jobs in Frontview
true though I should be able to set the text file output to a location on a share (or on my computer). In either case, in linux I should be able to pick these up and have them forwarded to me by email.or Frontview's email alerts about backup jobs
True - I was hoping to be able to set it up so it doesn't interfere with Frontview - maybe even allowing Frontview scheduling still to work if desired.you won't get help with this from tech support.
It doesn't seem there are inherent problems in Frontview to do this I don't know about then - thanks.
Though I don't know how to instruct ~ReadyNAS to terminate power to the USB ports - if it is even possible. My USB drives gives me no indication they have been unmounted.
Thanks for your help.
David - nitrox_johnAspirantHi, new here, and so ask for indulgence. This thread appears to be the most relevant place to lodge this one...
Like Davidr, we have implemented our own rsync backup to external USB drives, using EnableRootSSH. This gives us finer control over timing, mounting, error handling, disk rotations, reporting, etc.
All is working perfectly, however the underlying USB external drive automount is still occurring even though our scripts are managing the mounting themselves. This appears to have no adverse affect, other than I feel uncomfortably asking users to switch drives which are still mounted (not by our scripts, but by the automount).
Is there any way to disable external USB drive automount on the NVX without breaking other subsystems?
